Vandergraff
Dec 22, 2019Apprentice
disabling LAN ports on on RBS50
I am trying to disable the LAN ports on an RBS50 and following instructions here https://community.netgear.com/t5/Orbi/DISABLE-LAN-PORTS-ON-RBS50/m-p/1719465#M55199 That is: ----------------...
Dec 26, 2019Guru - Experienced User
Disabling ports on the RBS is not supported. Thus why you see the config error when you try to apply the change.
You might try Voxels 3rd party FW over on smallnetbuilders forum.
Vandergraff wrote:I am trying to disable the LAN ports on an RBS50 and following instructions here
That is:
- From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
- Enter admin as user name and your router’s management password
- Tick "Enable Telnet" option
- Use Telnet from your computer to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
- Enter the following commands:
- config get dgc_netif_lan_phyif --> printout should be eth1 for RBS50
- ifconfig eth1 down --> use the value that you got from the previous command
- ifconfig commit
Everything seems to work OK until last step - when enter 'ifconfig commit' I get 'ifconfig: commit: error fetching interface information: device not found'
Ideas or suggestions?
Note the print out for 'config get dgc_netif_lan_phyif' is eth1 so eberything seems to work up to there?
- VandergraffDec 28, 2019Apprentice
FURRYe38 wrote:Disabling ports on the RBS is not supported. Thus why you see the config error when you try to apply the change.
Why not? Seems a strange decision given that the Orbi Outdoor Satellite (RBS50Y) has no Ethernet ports (for somewhat obvious security reasons).
The RBS50Y seems functionally very similar to the RBS50
- CrimpOnDec 28, 2019Guru - Experienced UserThe RBS50Y has no physical ethernet port to disable.
CrimpOn wrote:
The RBS50Y has no physical ethernet port to disable.Understood - but why not allow the functionally similar RBS50 to turn off the Ethernet ports?
