corradokid
Nov 20, 2018Tutor
Disabling WMM Disables N? FW V2.2.1.210
While turning off WMM for both 2.4 and 5GHz in Advanced Setup -> WiFi Settings to see if my LIFX bulbs will stop randomly dropping the network, I noticed with WMM off my late 2011 MacBook Pro saw all...
dkleinknecht
Nov 30, 2018Star
Have you had any luck with your LIFX bulbs? I have a couple that keep dropping off the network and need to be re-setup probably weekly. The rest work fine but it's always these two, and I've even moved the bulbs around to where other ones are plugged in, but sure enough they keep dropping, so I don't think it's the pysical location of them (they're central anyway and have a strong signal).
Just curious because it's a bit of a pain and I never had these issues when I use my Amplifi setup instead of Orbi.
