WayneLTownsend
Oct 20, 2020Follower
Disconnect 5G on RBR20
I need to disconnect the 5G function so I can connect my weather station using the 2.4G. Any idea how to do that?
CrimpOn
Oct 20, 2020Guru - Experienced User
WayneLTownsend wrote:I need to disconnect the 5G function so I can connect my weather station using the 2.4G.
There is no method to turn off the Orbi 5G radio. A method that appears to work for many users is this:
- Access the Orbi web interface (http://orbilogin.net) using the admin credentials user "admin" and the Orbi router password (not the WiFi password)
- Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
- Uncheck the box "Broadcast SSID on 5G Channel"
This will not affect any devices which are currently attached to the Orbi at 5G. - On the smartphone settings, "forget" the Orbi WiFi
- Search for WiFi networks and select the Orbi WiFi
- Enter the WiF password and connect
- At this point, open the IoT app and go through the steps
- After the device is connected, reverse the steps
Check the box "Broadcast SSID"
"Forget Orbi WiFi"
Search for and connect.
- fmalloyOct 20, 2020Luminary
"Forget Orbi WiFi"
Your workaround is very helpful, thank you, but quite honestly...Netgear could simply add two checkboxes to be able to turn on/off the 2.4 and 5GHz radios independently. And while they're at it, allow separate network names for the two networks.
