WayneLTownsend
Oct 20, 2020Follower
Disconnect 5G on RBR20
I need to disconnect the 5G function so I can connect my weather station using the 2.4G. Any idea how to do that?
CrimpOn
Oct 20, 2020Guru - Experienced User
WayneLTownsend wrote:I need to disconnect the 5G function so I can connect my weather station using the 2.4G.
There is no method to turn off the Orbi 5G radio. A method that appears to work for many users is this:
- Access the Orbi web interface (http://orbilogin.net) using the admin credentials user "admin" and the Orbi router password (not the WiFi password)
- Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
- Uncheck the box "Broadcast SSID on 5G Channel"
This will not affect any devices which are currently attached to the Orbi at 5G. - On the smartphone settings, "forget" the Orbi WiFi
- Search for WiFi networks and select the Orbi WiFi
- Enter the WiF password and connect
- At this point, open the IoT app and go through the steps
- After the device is connected, reverse the steps
Check the box "Broadcast SSID"
"Forget Orbi WiFi"
Search for and connect.
fmalloy
Oct 20, 2020Luminary
This will not affect any devices which are currently attached to the Orbi at 5G.- On the smartphone settings, "forget" the Orbi WiFi
"Forget Orbi WiFi"
Your workaround is very helpful, thank you, but quite honestly...Netgear could simply add two checkboxes to be able to turn on/off the 2.4 and 5GHz radios independently. And while they're at it, allow separate network names for the two networks.
