jimmycrank
Jul 10, 2019Aspirant
Disconnecting Satellite log availability?
I have an orbi router, 2 rbs50 satellites, and a rbw30 satellite in AP mode. I have had the system for 2 years and just recently added the rbw30 about 2 months ago to extend to the garage. Things...
Jul 11, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
jimmycrank wrote:I have an orbi router, 2 rbs50 satellites, and a rbw30 satellite in AP mode. I have had the system for 2 years and just recently added the rbw30 about 2 months ago to extend to the garage. Things seemed to be working no issues for the last couple months but just started seeing one of the main satellites frequently disconnect. I can’t tell if it’s going bad or how often it disconnects or it’s just a UI bug. Is there a log that I can check to see how often it’s disconnecting?
