wolfbow
Mar 08, 2018Aspirant
disconnects and latency when using orbi
firmware V2.1.2.18 I am getting 5ms pings to my default gateway, which is 5x what I would expect to observe and random >100 pings to other hosts on the LAN. Kids claim of random lag and disconn...
Mar 09, 2018Guru - Experienced User
You can test with Beamforming, MIMO, Daisy Chain and Fast Roaming disabled and see if anything helps. I've disabled all of these and has helped in most configurations.
Currnet versions of FW aren't the greatest and everyone is waiting on the next update.
It's recommended to connect game consoles via ethernet for best gaming performances.
wolfbow
Mar 09, 2018Aspirant
all of them are disabled and ethernet isn't a great option. thanks for the reply.
- FURRYe38Mar 09, 2018Guru - Experienced User
Might have to wait for next FW update.
Good Luck.
