fakeout1010
Jul 22, 2017Aspirant
Disconnects from satellite on chromecast
I have an Orbi with 1 satellite. Until today everything seemed to work fine. The issue I'm having today is that my Chromecast which is connecting to the Satellite automatically (the Satellite is about 40-50ft from the router) is randomly dropping connection. If I disable the Satellite it connects to the router and everything works fine. If I plug the Satellite in it connects to it and will drop within 30 minutes. I have the latest firmware and did a factory reset. Any ideas or troubleshooting tips? I have two Chromecast and both exhibit the same problem when plugged in at this location with the satellite on so I know I don't just have a bad chromecast.
- st_shawMaster
Try moving the satellite closer to the router.
- cyberprashantLuminaryTheres lots of post about the latest firmware having issues 1.12.0.18....see if you have that one. I had problems with the amazon echo dropping off of the wifi prev stable. I believe its firmware related. Switching amazon to guest orbi network seems to have stopped. Others have suggested downgrading firmware and blocking updates will help
- fakeout1010AspirantYes that is the firmware I have but I'm not sure how to roll back or disable updates.
- cyberprashantLuminarySee page number five of the thread called 1.12.0.18 discussion.
It's a little involved but not too bad and solve my problems of the dropping amazon echo of the network every few minutes
- fakeout1010AspirantThe satellite was closer, about 20 ft, so I moved it further thinking that could help. Neither make a a difference.
