ambros
Mar 23, 2019Star
DIscrepancy Between Orbi Traffic Monitor and ISP's Reported Bandwidth Usage
Is anyone else noticing a discrepancy between what the Orbi Traffic Meter reports versus what your ISP (specifically Comcast) is reporting? Before I complain to Comcast I was hoping to see if anyone ...
- Apr 29, 2019
It does appear to be working as expected with the latest firmware, or close enough within fault tolerance. Monthly, Yesterday, and Today records seem to fall within acceptable expectation.
April:
Orbi - 610GB
ISP - 588GB
Tap - 540GB
I expect the Orbi to have the highest record since it should actively track every bit of data running through it at full line rate.
I expect the Tap to have the lowest record since it it limited to USB 2.0 Bus speed (Raspberry Pi) and therefore will not fully record any traffic exceeding ~300mbit/sec.
I expect the ISP record to sit between the Orbi and Tap as a general guideline due to the previously mentioned reasoning as well as being on an expected slight delay.
Mar 25, 2019Guru - Experienced User
What FW is currently loaded?
Was the traffic monitoring setup at the same start cycle as the ISP when tracking traffic?
Not many users have mentioned this...
