ambros
Mar 23, 2019Star
DIscrepancy Between Orbi Traffic Monitor and ISP's Reported Bandwidth Usage
Is anyone else noticing a discrepancy between what the Orbi Traffic Meter reports versus what your ISP (specifically Comcast) is reporting? Before I complain to Comcast I was hoping to see if anyone ...
- Apr 29, 2019
It does appear to be working as expected with the latest firmware, or close enough within fault tolerance. Monthly, Yesterday, and Today records seem to fall within acceptable expectation.
April:
Orbi - 610GB
ISP - 588GB
Tap - 540GB
I expect the Orbi to have the highest record since it should actively track every bit of data running through it at full line rate.
I expect the Tap to have the lowest record since it it limited to USB 2.0 Bus speed (Raspberry Pi) and therefore will not fully record any traffic exceeding ~300mbit/sec.
I expect the ISP record to sit between the Orbi and Tap as a general guideline due to the previously mentioned reasoning as well as being on an expected slight delay.
ambros
Apr 01, 2019Star
Initial results are varied as expected, but a new month just started and hopefully get some legit data now. I've been tracking changes as reported by both my ISP and Orbi Traffic Meter starting about a week ago. I picked an arbitrary starting point for a baseline and have measured the differences over the last ~7 days. While running the latest firmware, initial results show similar values recorded by both with a ~3GB discrepancy opposite of the original thread starting situation (Orbi now shows higher usage than ISP) with some back and forth from day to day.
Router Firmware Version
V2.3.1.44
https://docs.google.com/spreadsheets/d/1o5DLhMMG4NNP9dSz5jUfrnaTe7TG0Nze-3Op7eASWWg/edit?usp=sharing
I am also using my network tap bandwidth monitoring solution, however I while I was expecting the Orbi Traffic Meter to reset this morning at midnight, I was not expecting the value for "Yesterday" to clear when the value for "Last Month" does not clear (screenshot attached). From memory and for most part, the Orbi and Network Tap seem to be reporting similar results; will clarify with data tomorrow.
As of right now, stats for today:
Network Tap: 3.43GB
Orbi Traffic Meter: 3.177GB
But with a grain of salt since its a moment in time during a 24 hour period of recording.
ambros
Apr 09, 2019Star
More time brings better results... looks like the new firmware seems to be working better, but there's not enough evidence to claim this was the initial underlying issue.
Comparing Orbi Traffic Meter to both the Raspberry Pi running vnstat and Comcast's app, the numbers appear to match. There are slight discrepancies due to the beforementioned RPi network interface speed being limited to the USB2.0 bus (~300 mbit/s). If the Orbi reported lower numbers than the RPi, then it would be an issue; since the Orbi shows greater values, it's inconclusive, but not unexpected.
