franktribe
Apr 27, 2018Apprentice
Disney Circle and Factory Reset
I am sure some of you figured this out. But, it is worth repeating. Backup your Disney Circle settings! It is in the Disney Circle App under manage. If you do a factory reset, and re-enable Disney Circle, it will act like you never set it up. You have to go through the account creation process again., then once you are in, restore your settings. Thank goodness I backed up my profiles. It's kind of obvious to backup your settings but, just in case you forgot, back them up! I really like my Orbi and Disney Circle. Things like backing up them make me continue to like it :-)
1 Reply
- DarrenMSr. NETGEAR Moderator
Thanks for sharing this great tip!
DarrenM
