vannar
Mar 16, 2019Aspirant
Disney Circle installed on Orbi Router-Passcode Problems
I have an orbi router with Disney circle installed on it. I use to be able to login to my Disney circle account on my iPhone. Now my passcode is not working and when I ask for it to be sent to me,...
vannar
Than you for your response, but I have read over several threads and tried everything I can do on my end to fix it.
It seems like most people fix this issue by having a moderator help them and get the passcode from the server.
Thanks again!!
Thanks again!!
- FURRYe38Mar 16, 2019Guru - Experienced User
Please post there and I'm sure someone will help you there.
- Blanca_OMar 18, 2019NETGEAR Employee Retired
- armandobesaMay 27, 2019AspirantSame issue here. Tried to verify through passcode but always failed. I kept resending and same code keeps failing?
- FURRYe38May 28, 2019Guru - Experienced User
Please post about this in the Circle forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Thank you.
