DDK134
Nov 27, 2017Tutor
Disney Circle on Orbi - when will it be available
The Disney Circle offering sounds great. When will it be available on the ORBI?
Krague17
Dec 04, 2017Aspirant
Any timeframe on release? The build in parental controls that use OpenDNS are not working and not very robust. Disney Circle seems like the best solution. Please hurry up and make it available.
AmitR
Dec 05, 2017NETGEAR Employee Retired
It's available here:
https://community.netgear.com/t5/Orbi/Announcing-availability-of-OrbiOS-2-1/m-p/1447612#M16893
- DDK134Dec 05, 2017Tutor
Awesome! Now to try it out...
- loomis1975Dec 05, 2017Luminary
We still need the physical Disney Circle device correct? Its not virtual via the Orbi is it?
- AmitRDec 05, 2017NETGEAR Employee Retired
No. When you upgrade to MR 2.1, you will not need a separate Circle device. The Circle software is in the Orbi. You wIll still need Circle App.
- johnbendeverDec 13, 2017Aspirant
I do not see an option for RBS units, did I miss it?
- DarrenMDec 13, 2017Sr. NETGEAR Moderator
Hello johnbendever
You will have to do a manual update of the firmware to version 2.1 I have linked it below.
https://community.netgear.com/t5/Orbi/Announcing-availability-of-OrbiOS-2-1/td-p/1447612
DarrenM
