rao24
Nov 29, 2018Aspirant
Disney Circle Passcode
I'm unable to login to meetcircle passcode. I'm the admin but it keeps asking for a passcode. I dont have it and tried with 'send code' option but never received any SMS.
How to get rid of this p...
michaelkenward
May 18, 2019Guru - Experienced User
EftyM wrote:
Hi I lost connection to Circle and it would not connect.
Have you also tried asking in the Circle bit of this community?
EftyM
Aug 20, 2019Aspirant
- FURRYe38Aug 20, 2019Guru - Experienced User
Please post about this in the Circle app forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
https://www.netgear.com/support/product/circle.aspx- EftyMAug 20, 2019Aspirant
Please note that I have done this and not had any response. Surely Netgear should be able to provide me with a way to reset the password????
I cannot use the Parental controls as I cannot access the app without first logging in. Whenever I have tried to request a new password, it says it will send a replacement password to my mobile phone but this never happens.
Can someone at NetGear PLEASE HELP!!
Thanks
Efty Mateides
Is this for a R7000P?
IF so I would also post about this in the Nighthawk forum:
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
EftyM wrote:Please note that I have done this and not had any response. Surely Netgear should be able to provide me with a way to reset the password????
Thanks
Efty Mateides
