MunkMan's avatar
MunkMan
Disney Plus connection
All,
within the last week my Orbi Mesh will not allow me to connect to Disney Plus anylonger, all other connectivity is fine to netflix, you tube tv, internet etc...
If i go direct from my Fiber to my PC i can get to Disney plus, but going through the Orbi its not allowing me.
I see that there might be an issue with the Circle and it causing an issue?
Anyone have an answear?
Thanks
Patrick
  • FURRYe38's avatar
    The issue is with Disney. Someone posted about this not too long ago...they ask same thing...came back and said the issue was corrected by Disney.
    • MunkMan's avatar
      MunkMan
      Did they contact disney or how was it resolved?
      • FURRYe38's avatar
        I believe so...I was looking for the post thread but can't find it.
        Also do you have Armor or Circle enabled on the RBR?
