Dortmonster
Aug 13, 2020Initiate
Disney+ Won't Stream Through Orbi Router
I just reasontly lost the ability to stream Disney+ through my Orbi router. All other streaming services (Netflix, AmazonPrime Video, etc.) all work. If I switch off the Orbi router to my regular c...
Mstrbig
Aug 13, 2020Master
Dortmonster wrote:I just reasontly lost the ability to stream Disney+ through my Orbi router. All other streaming services (Netflix, AmazonPrime Video, etc.) all work. If I switch off the Orbi router to my regular cable modem router it works. I tried deleting Circle thinking that might be blocking it, but that didn't work either. Has anybody else seen this issue and is there a solution?
Have you changed any settings, modified your network, updated your virus protection etc, in any way? What are the actual symptoms of Disney Plus?
- MstrbigAug 14, 2020Master
As a followup, I just installed Disney+ on the rest of my home TVs, ands streaming devices. With a standard Orbi setup, with no modifications, except some UPNP camera settings, Disney+ plays perfect on all devices, even one that I had to side load the app on.
- DortmonsterAug 16, 2020Initiate
I have not modified any of the system settings prior to this occuring and there hasn't been any virus updates to my knowledge installed.
The error i am getting when trying to stream on Disney+ is an "Opps something went wrong" error when i try to play a movie. I am able to get into Disney+ and navigate around to all the menus and make selections to play movies, but it just won't play the video.
- MstrbigAug 16, 2020Master
Unless you are blocking something, Orbi acts like any other router, mesh system and would not, by itself cause this issue.
What device are you using for Disney+? It could be the device. Try resetting the device. Also, I have an android box that I downloaded Disney+ app. It won'y play movies. Support told me their app is not compatible with the version of andriod I have and I would need to update. Unfortunately there is no update. I'm menbtioning this as this could be your problem as well.
- VkrishAug 23, 2020AspirantSomething for me.
