Dortmonster
Aug 13, 2020Initiate
Disney+ Won't Stream Through Orbi Router
I just reasontly lost the ability to stream Disney+ through my Orbi router. All other streaming services (Netflix, AmazonPrime Video, etc.) all work. If I switch off the Orbi router to my regular c...
Mstrbig
Aug 13, 2020Master
Dortmonster wrote:I just reasontly lost the ability to stream Disney+ through my Orbi router. All other streaming services (Netflix, AmazonPrime Video, etc.) all work. If I switch off the Orbi router to my regular cable modem router it works. I tried deleting Circle thinking that might be blocking it, but that didn't work either. Has anybody else seen this issue and is there a solution?
Have you changed any settings, modified your network, updated your virus protection etc, in any way? What are the actual symptoms of Disney Plus?
Mstrbig
Aug 14, 2020Master
As a followup, I just installed Disney+ on the rest of my home TVs, ands streaming devices. With a standard Orbi setup, with no modifications, except some UPNP camera settings, Disney+ plays perfect on all devices, even one that I had to side load the app on.
