Dortmonster
Aug 13, 2020Initiate
Disney+ Won't Stream Through Orbi Router
I just reasontly lost the ability to stream Disney+ through my Orbi router. All other streaming services (Netflix, AmazonPrime Video, etc.) all work. If I switch off the Orbi router to my regular c...
billasch
Dec 19, 2020Guide
I am having the same problem, I found this thread where NetGear support changed settings and got it to work, but I am completely screwed right now.
Does anyone know how I can fix my Orbi to allow me to see DisneyPlus? I would hate to have to buy an ENTIRELY new mesh network to solve this...or to pay for a VPN service. sigh*
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Disney-not-working-with-Orbi-Router/m-p/1898291/highlight/true
- FURRYe38Dec 19, 2020Guru - Experienced User
billasch wrote:I am having the same problem, I found this thread where NetGear support changed settings and got it to work, but I am completely screwed right now.
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Disney-not-working-with-Orbi-Router/m-p/1898291/highlight/true- billaschDec 19, 2020Guide
FURRYe38 wrote:What Firmware version is currently loaded?
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Disney-not-working-with-Orbi-Router/m-p/1898291/highlight/trueFirmware: v2.5.2.4
MFR and Model of ISP modem: Xfinity - Technicolor CGM4331COM- FURRYe38Dec 19, 2020Guru - Experienced User
Is Armor or Circle enabled on your Orbi?
Your ISP modem already has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended.
What mode is the modem working in?
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
billasch wrote:Firmware: v2.5.2.4
