Dortmonster
Aug 13, 2020Initiate
Disney+ Won't Stream Through Orbi Router
I just reasontly lost the ability to stream Disney+ through my Orbi router. All other streaming services (Netflix, AmazonPrime Video, etc.) all work. If I switch off the Orbi router to my regular c...
billasch
Dec 19, 2020Guide
I am having the same problem, I found this thread where NetGear support changed settings and got it to work, but I am completely screwed right now.
Does anyone know how I can fix my Orbi to allow me to see DisneyPlus? I would hate to have to buy an ENTIRELY new mesh network to solve this...or to pay for a VPN service. sigh*
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Disney-not-working-with-Orbi-Router/m-p/1898291/highlight/true
Dec 19, 2020Guru - Experienced User
billasch wrote:I am having the same problem, I found this thread where NetGear support changed settings and got it to work, but I am completely screwed right now.
- billaschDec 19, 2020Guide
FURRYe38 wrote:What Firmware version is currently loaded?
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Disney-not-working-with-Orbi-Router/m-p/1898291/highlight/trueFirmware: v2.5.2.4
MFR and Model of ISP modem: Xfinity - Technicolor CGM4331COM- FURRYe38Dec 19, 2020Guru - Experienced User
Is Armor or Circle enabled on your Orbi?
Your ISP modem already has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended.
What mode is the modem working in?
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
billasch wrote:Firmware: v2.5.2.4
MFR and Model of ISP modem: Xfinity - Technicolor CGM4331COM- billaschDec 19, 2020Guide
FURRYe38 wrote:Is Armor or Circle enabled on your Orbi?
Couple of options,
MFR and Model of ISP modem: Xfinity - Technicolor CGM4331COMNope, No armor and No Circle...no Parental controls
1) The modem is in Bridge mode.
2) It's in Bridge and all the WiFi broadcasts from the Xfinity router are off.
I will read the KB articles, just in case. It seems clear though, that this is not just me. Very weird indeed.
Every device in my home that connects to the Orbi has Disney blocked. I've now checked them all connected via the Orbi
1) 3 Desktops (all with virus scanners disabled...2 run Kaspersky and 1 runs AVG)
2) 2 laptops (1 bitdefender, 1 kaspersky)
3) 2 Samsung S7 phones
4) 2 Google Pixel XLs
But the moment I hit Verizon data...boom...it works great.
