Dortmonster
Aug 13, 2020Initiate
Disney+ Won't Stream Through Orbi Router
I just reasontly lost the ability to stream Disney+ through my Orbi router. All other streaming services (Netflix, AmazonPrime Video, etc.) all work. If I switch off the Orbi router to my regular c...
Dec 20, 2020Guru - Experienced User
Ok, so the device that has Disney on it, put that devices IP address into the DMZ on the RBR and see what happens.
billasch
Dec 20, 2020Guide
OK...here's the deal, we can close this. And I would like to thank for you for help.
I have dug all over the Interwebz and it seems that Disney blocked a lot of IP Addresses over the last year. I chatted with them online and they were able to unblock the IP.
It was NOT the Orbi!!!
Again, thanks for all your help.
- MstrbigDec 20, 2020Master
I was just getting ready to tell you the same thing. Glad to hear you found the solution. Please mark your findings as the solution?
- FURRYe38Dec 20, 2020Guru - Experienced User
AH cool Glad it wasn't Orbi.
Enjoy.
Select the Solution button seen in this thread.
Oops. the OP will have to mark the Solution button. Hopefully they will come back and confirm it.
