koolmeme
Jan 30, 2017Tutor
Distance Between Router and Satellite - Max?
I have a house that is much longer (100ft end-to-end) than it is wide. Wanting to place the Orbi router in the middle with satellites at front and back. So the question is ... 50ft between router a...
- Jan 31, 2017
Searched few other threads ... found references to 60ft-75ft between router and satellite, including estimates from NETGEAR. So that should be doable for my requirements.
cue003
Jan 30, 2017Apprentice
You would most likely put the orbi router in the center of your home then the satellites in the center of the the rest of the area. So really only 25-30 feet between satellites and router.
Wall ----satellite----router----satellite---- Wall type of run.
0ft. 25ft. 50ft. 75ft. 100 ft.
koolmeme
Jan 30, 2017Tutor
In my desired setup, the two best locations for satellite placement are close to the front/back walls as I want to leverage the Orbi ethernet ports for some older peripherals. Those extra ports and the dedicated 5GHz backhaul are my reason for leaning Orbi but ...
I measured the farthest run in this setup and the router to satellite separation comes in right at 50' ... so is 50' separation doable using the Orbi setup (y/n)?
To clarify, single-story house. Built 2010. Walls are not particularly obtrusive to my current Airport Extreme router (circa 2010), which I am looking to replace.
- NarkhelekJan 30, 2017Aspirant
Distance is a really poor indicator of performance in a wifi environment. You should go by -dB loss between router and satelite by using any of the phone wifi survey apps or something on your laptop (I use Wifi Analyzer on Android). I have a narrow wide 2 story house and I setup router and satelite at opposite ends of the house on different floors (fortunately I already had CAT5 ran from where my cable modem is to one end of the house). This provided the best coverage while also extending reach around my property.
Basically my thought process was to find a locations that was about -60dB between router and satelite. This would provide for excellent backhaul between router and satelite while maximizing coverage.
- koolmemeJan 31, 2017Tutor
