giovannicono
Dec 29, 2021Follower
Divide 5G Orbi RBR350
I've an IoT device to connect to Orbi Wi-Fi, but it need to have a separate SSID for 5G and 2.4G to work. As i can read, Orbi new firmware doesn't allow to divide the two SSID. I tried to switch off ...
Dec 29, 2021Guru - Experienced User
So you might want to also change the power output of the 5Ghz radio to 25% on the RBR. Turn OFF any RBS while you try this. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
FYI, Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
giovannicono wrote:
I've an IoT device to connect to Orbi Wi-Fi, but it need to have a separate SSID for 5G and 2.4G to work. As i can read, Orbi new firmware doesn't allow to divide the two SSID. I tried to switch off 5G from router settings, but when I turn it on again IoT device stop working, I don't know why this works for other users.
Is there another solution?
