sprstrx
Apr 07, 2021Tutor
DM200 & Orbi RBR50/ RBS50 - Not Connected
I have had a Netgear DM200 modem connected to a Orbi RBR50 for a couple of years and have encountered 0 issues. Yesterday my internet connection dropped and the power led on the DM200 was flashing am...
- Apr 09, 2021
Ha_Ku_Na wrote:
sprstrx wrote:I have the router provided by my ISP which is what I'm currently using but it's pretty limited in what it can do and can't be used in Modem Only mode
I would use the ISP provided router and connect the RBR to this router.
And if the ISP provided router has WIFI, turn it off.
What type of ISP router you have ?
Could you set a "static-route" there ?A little picture to better show what I mean.
Doesn't matter if the ISP provided router has limited functionality.
Therfore you have the ORBI system where you connect all your switches, devices, ...
The IP addresses can change, adapt it accordingly
vajim
Apr 07, 2021Master
Orbi firmware?
BoilerPlate
Apr 07, 2021Apprentice
Wow, and Again NOT a firmware issue. Imaging that.
- vajimApr 07, 2021Master
BoilerPlate wrote:Wow, and Again NOT a firmware issue. Imaging that.
The hottest subject in this forum.
