sprstrx
Apr 07, 2021Tutor
DM200 & Orbi RBR50/ RBS50 - Not Connected
I have had a Netgear DM200 modem connected to a Orbi RBR50 for a couple of years and have encountered 0 issues. Yesterday my internet connection dropped and the power led on the DM200 was flashing am...
- Apr 09, 2021
Ha_Ku_Na wrote:
sprstrx wrote:I have the router provided by my ISP which is what I'm currently using but it's pretty limited in what it can do and can't be used in Modem Only mode
I would use the ISP provided router and connect the RBR to this router.
And if the ISP provided router has WIFI, turn it off.
What type of ISP router you have ?
Could you set a "static-route" there ?A little picture to better show what I mean.
Doesn't matter if the ISP provided router has limited functionality.
Therfore you have the ORBI system where you connect all your switches, devices, ...
The IP addresses can change, adapt it accordingly
vajim
Apr 08, 2021Master
looks like this has been discussed before:
https://community.netgear.com/t5/Orbi/Orbi-set-up-with-DSL-Model/m-p/1919366
sprstrx
Apr 08, 2021Tutor
vajim wrote:looks like this has been discussed before:
thanks vajim
I have followed that process but still have no luck.
This was how I initially configured my set up in 2019 and it worked fine until a couple of days ago.
I'm inclined to think that there is an issue with the Orbi as the DM200 allows me a access the internet in Modem & Router mode
- FURRYe38Apr 08, 2021Guru - Experienced User
So does the Orbi connect using DHCP with the DM modem in router mode at all?
Try swapping LAN cables between the RBR and Modem? CAT 6 is recommended.
- sprstrxApr 08, 2021Tutor
FURRYe38 wrote:So does the Orbi connect using DHCP with the DM modem in router mode at all?
It did not connect
I have tried tried swapping out the cables but it hasn't made a difference. Unfortunately I only have Cat 5e cables available at the moment but I'll try get hold of a Cat 6 cable tomorrow
Don't happen to have a prior or different router on hand to test with do you?
