crimvo's avatar
crimvo
Follower
May 22, 2019
DMZ does not work
Hey all,
Just got the Orbi AC3000 RBK50 router mesh network, and so far its great except that DMZ is not working. Port forwarding seems to work, but I would rather manage the firewall for my server using IP Tables, as I have always done, and forwarding to that using DMZ. However even though I have the correct server set in WAN setup for default DMZ server, it is not opening the ports. When attempting to telnet to 22 for instance, I get connection refused, until I add that port to forwarding.
Any ideas would be appreciated.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    So your using a different DHCP server on the same network?
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi crimvo
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    Blanca
    Community Team
  • crimvo wrote:
    ............. When attempting to telnet to 22 for instance, I get connection refused, until I add that port to forwarding.
    Are you sure that your ISP modem/router is not the one who blocks the telnet request and not Orbi?
    Do you see any input in the Orbi Logs when you try the telnet?
