komrade
Jan 23, 2019Guide
DNS Forwarding and dnsmasq on RBR20
Hello!
I've set up a Pi-Hole on my network and mostly everything is working fine. It looks like the Orbi is running dnsmasq itself to check DNS against something (orbilogin.com ?) and if it's not ...
komrade
Jan 23, 2019Guide
Ah, got it.
Slightly related: enabling DHCP to be handled by the raspi would effectively solve for this. Any reason the Orbi system would suffer if I turn off DHCP on the Orbi?
Jan 23, 2019Guru - Experienced User
Having two DHCP services would cause problems if running same IP address pool.
If you have DHCP handing by the Pi, why not change the Orbi configuration to AP mode, then you'll get what your DHCP/DNS server puts out to any connected client.
