capGrundy
Mar 18, 2021Aspirant
DNS problems
How do you have a static IP, but dynamic DNS? When static IP is selected, you cannot change the DNS option. I just started having problems where my DNS would fail until I re-appliled the curre...
- Mar 18, 2021
capGrundy wrote:I'm going to see how C.i works out with the restarts. A similar fix helped me with a proxy hang on my server.
If they persist, I appreciate the suggestion. Since I was unwilling to pay for product support beyond the short warranty period, I'm not sure they would be willing to help me.
Good luck. This issue coupled with faulty firmware has finally gotten the NG moderators here involved. Hopefully things will settle down for you and others soon.
:smileyhappy:
vajim
Mar 18, 2021Master
perhaps this will help:
with attention to post #5
- capGrundyMar 18, 2021Aspirant
Thank you for the response. I had already done A, B, and F. I did both C options to see if that helps. D & E seem insane for an off the shelf of a commercial, user-friendly router.
It's a strange juxtaposition, where so many basic features and support are paywalled, but fixes seem to require shell level skills to conduct.
- vajimMar 18, 2021Master
capGrundy wrote:Thank you for the response. I had already done A, B, and F. I did both C options to see if that helps. D & E seem insane for an off the shelf of a commercial, user-friendly router.
I believe your best bet is to reach out to ChristineT
