capGrundy
Mar 18, 2021Aspirant
DNS problems
How do you have a static IP, but dynamic DNS? When static IP is selected, you cannot change the DNS option. I just started having problems where my DNS would fail until I re-appliled the curre...
- Mar 18, 2021
capGrundy wrote:I'm going to see how C.i works out with the restarts. A similar fix helped me with a proxy hang on my server.
If they persist, I appreciate the suggestion. Since I was unwilling to pay for product support beyond the short warranty period, I'm not sure they would be willing to help me.
Good luck. This issue coupled with faulty firmware has finally gotten the NG moderators here involved. Hopefully things will settle down for you and others soon.
:smileyhappy:
capGrundy
Thank you for the response. I had already done A, B, and F. I did both C options to see if that helps. D & E seem insane for an off the shelf of a commercial, user-friendly router.
It's a strange juxtaposition, where so many basic features and support are paywalled, but fixes seem to require shell level skills to conduct.
vajim
Mar 18, 2021Master
capGrundy wrote:Thank you for the response. I had already done A, B, and F. I did both C options to see if that helps. D & E seem insane for an off the shelf of a commercial, user-friendly router.
I believe your best bet is to reach out to ChristineT
- capGrundyMar 18, 2021Aspirant
- vajimMar 18, 2021Master
:smileyhappy:
- MTownsendMar 18, 2021Aspirant
I've been having the same issues this week on my system that I'd had for years. Was happy to see I'm not alone as I thought the HW might be giving up. For reference, if the mods see this, I had the slightly older 102 version still installed and updated to 104 to see if that would fix it. Just found the reddit post today and trying solution F (NTP fix) as that would make some sense as it just started happening this week. (Bug doesn't make sense, but the timing).
I did have a PiHole setup for DNS, but don't like how the DCHP server still sends the router IP out instead of the specified DNS server IP to every device, that never made sense to me before this either. Tore everything down to debug this problem this week and will have to rebuild the network after this is fixed hopefully soon. I feel for any non-techy person that runs into this issue as this will not be easy for them to figure out.Matt
