capGrundy's avatar
capGrundy
DNS problems
How do you have a static IP, but dynamic DNS?  When static IP is selected, you cannot change the DNS option.     I just started having problems where my DNS would fail until I re-appliled the curre...
  • vajim's avatar
    vajim
    Mar 18, 2021
    capGrundy wrote:
    I'm going to see how C.i works out with the restarts.  A similar fix helped me with a proxy hang on my server.
    If they persist, I appreciate the suggestion.  Since I was unwilling to pay for product support beyond the short warranty period, I'm not sure they would be willing to help me.
    Good luck.  This issue coupled with faulty firmware has finally gotten the NG moderators here involved.  Hopefully things will settle down for you and others soon.
    :smileyhappy:
