jasonrdunn
May 28, 2019Star
DNS Rebinding & Permitting a private domain
I use PLEX with my Orbi, and a PLEX developer is helping me solve some issues. He's telling me to find the settings for DNS Rebinding and allow plex.direct to be permitted. The problem is, despite lo...
May 28, 2019Guru - Experienced User
Does making any changes to DNS under Setup/Internet do anything?
Possible that this could be DNS proxy or DNS relay which means though you input a custom DNS for internet settings, regardless of what this address is, all connected client devices will get a 192.168.1.1 DNS address.
Possible loop back support could be an issue as well.
Something you might contact NG support about:
jasonrdunn
May 30, 2019Star
Hi there! Thanks for respoding. Firmware is V2.3.1.60. The modem is from CenturyLink and I have it in bridge mode, so it's not involved in DNS/IP dishing out at all. It functions as a "dumb" modem now. I will try contacting Netgear support since it seems there isn't a way to do what I need...though I suspect they'll just tell me it's not possible.
- jasonrdunnMay 30, 2019Star
Wow....
Hardware Warranty: ExpiredPhone Support: ExpiredEmail Support: ExpiredChat Support: ExpiredPower Supply Warranty: ExpiredAccessories Warranty: ExpiredSo Netgear will completely block customers using their products from contacting the company for support if the product is out of warranty? I've never seen that before...most places will offer some basic email support at worst. Wow. How utterly anti-consumer this approach is. :smileyfrustrated:- FURRYe38May 30, 2019Guru - Experienced User
Let us know how it turns out.
