lookout2015
Feb 09, 2017Tutor
DNS setting doesn't really work
Installed the 3-pack Orbi system yesterday, updated to current firmware (1.4.0.34), reset, then configured and put into use. Overall has worked pretty well but I'm hitting one issue that's becoming a...
DarrenM
Feb 15, 2017Sr. NETGEAR Moderator
Hello lookout2015
Is there possibly DNS settings in the modem that you are using?
DarrenM
- lookout2015Feb 17, 2017Tutor
Nope. Nothing configurable in the modem at all -- it just passes what it gets from the ISP
