lookout2015
Feb 09, 2017Tutor
DNS setting doesn't really work
Installed the 3-pack Orbi system yesterday, updated to current firmware (1.4.0.34), reset, then configured and put into use. Overall has worked pretty well but I'm hitting one issue that's becoming a...
MarkC1024
Feb 15, 2017Luminary
What do you have set under Internet setup? Is that still set to get automatically from ISP?
lookout2015
Feb 17, 2017Tutor
Under Internet
- IP Address is set to Get Dynamically from ISP
- Domain Name Server Address is set to Use these
and then I have a primary and secondary filled out
I'm also using IPv6 so under Advanced, IPv6, IPv6 Domain Name Server I have Use these set and then a primary and secondary filled out
- MarkC1024Feb 17, 2017Luminary
Hard to say as I just use what is assigned - haven't really tested setting my own.
