Jayhawk87
Mar 19, 2021Aspirant
DNS stops working
About 1 week ago started to have issues with my Orbi stopping DNS resolution. I am running the latest version of firmware (V2.7.2.104) and running Armour Security. I do have DNS setup to the router...
CrimpOn
Mar 19, 2021Guru - Experienced User
Correct. This is a raging issue right now. A good summary of possible solutions can be found in this post:
II have just seen posts suggesting that disabling Traffic Meter (in the Advanced Setup Menu) might help.
It is pretty clear that *something* is happening that mangles the DNS process.
No official solution from Netgear so far.
- Jayhawk87Mar 19, 2021Aspirant
Thanks for the link to the possible solutions. Best solution would be for NetGear to fix the issue all together. I am trying the disabling of the NTP auto adjustment for daylight savings time. We will see if that helps or not.
