Jayhawk87
Mar 19, 2021Aspirant
DNS stops working
About 1 week ago started to have issues with my Orbi stopping DNS resolution. I am running the latest version of firmware (V2.7.2.104) and running Armour Security. I do have DNS setup to the router...
CrimpOn
Mar 19, 2021Guru - Experienced User
Correct. This is a raging issue right now. A good summary of possible solutions can be found in this post:
II have just seen posts suggesting that disabling Traffic Meter (in the Advanced Setup Menu) might help.
It is pretty clear that *something* is happening that mangles the DNS process.
No official solution from Netgear so far.
Jayhawk87
Thanks for the link to the possible solutions. Best solution would be for NetGear to fix the issue all together. I am trying the disabling of the NTP auto adjustment for daylight savings time. We will see if that helps or not.
