Jayhawk87
Mar 19, 2021Aspirant
DNS stops working
About 1 week ago started to have issues with my Orbi stopping DNS resolution. I am running the latest version of firmware (V2.7.2.104) and running Armour Security. I do have DNS setup to the router...
Mar 22, 2021Guru - Experienced User
vajim
Mar 22, 2021Master
FURRYe38 wrote:Try the suggestion to see if it helps you out.
robertneaves wrote:Same problem!
Netgear will fix it....until the next firmware update
- robertneavesMar 23, 2021Aspirant
I did make the NTP change and disable the traffic meter. 24 hours later and no problems yet.
