mini4mw
Mar 22, 2021Guide
dnsmasq failure
I was running V2.5.1.16 and have been for 6+ months no issue. The other night the internet went down and I logged into the Orbi via web and verified the provider issue. While there I noticed the up...
- Mar 25, 2021
based on same thread and update from reddit;
i upgraded again to 2.6.2.104. Within 4 hours I had two more DNS outages. Same as before, DNS lookups to orbi router timing out. Log into router via telnet, reload the config (I'm not sure if dnsmasq was dead, just started documenting pid after last outage) and it started working again. On the 3rd outage I turned DST off (Advanced->administration->NTP->uncheck DST). I reloaded dnsmasq again (no reboots) and so far I've been good for 4 hours. Hopefully this fixes the issue. 1 hour off doesn't matter too much to me.
Apr 11, 2021Guru - Experienced User
You can ask for a beta:
Tralfazus wrote:What is the status of a fix for the Orbi DNS/DST failure?
Once a workaround was announced, there has been dead air as far as I can tell.
