sarahgnm
Oct 30, 2019Aspirant
do i need a satellite?
We have a 2000 sq ft house on one floor. We set up our Orbi RBK50 with a satellite on the other end of the house (where the wifi signal has been weaker with the previous router). There are a few se...
Oct 30, 2019Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
sarahgnm wrote:We have a 2000 sq ft house on one floor. We set up our Orbi RBK50 with a satellite on the other end of the house (where the wifi signal has been weaker with the previous router). There are a few seconds of drop from network on iPhone when you walk away from router and toward satellite. One computer (a new one) experiences drops from the internet that last several minutes when it is not close to the router. Is it because the computer is changing connection from router to satellite and getting confused? Do we really need the satellite in this size house?
