sarahgnm
Oct 30, 2019Aspirant
do i need a satellite?
We have a 2000 sq ft house on one floor. We set up our Orbi RBK50 with a satellite on the other end of the house (where the wifi signal has been weaker with the previous router). There are a few se...
sarahgnm
oops. It's an RBR50.
The satellite is over 40 feet away from the router and synced easily (blue light).
Since I wrote first question, I have had the same interrupted internet on the same (new) computer, while the satellite was turned off, so that is not the problem. Meanwhile other devices on the wifi network are functioning well. Therefore, I conclude that the wifi network is not the problem.
I appreciate the replies. One was like a foreign language (I don't understand wifi networking very well). But I have learned that the phone app for orbi isn't much use, have downloaded the user manual, and will learn how to manage the wifi network using a browser. So thanks for responding.
CrimpOn
Oct 30, 2019Guru - Experienced User
sarahgnm wrote:oops. It's an RBR50.
Yes, the RBK50 is a "Kit" containing one RBR50 router and one RBS50 satellite. Similarly, the RBK53 is a kit with one router and two satellites. (Why 2 devices = "0" and 3 devices = "3" is one of those marketing mysteries.)
