kevin3151's avatar
kevin3151
Initiate
May 01, 2020
Do not buy unless you are willing to deal with these shortcomings
I just bought the orbi voice speaker and updated to the latest firmware. I am having the same problems that others are with the volume not working. There are questions and threads about this that have not been resolved for almost a year. Apparently software updates arent fixing it.
The volume control intermittently stops working requiring a reboot.   This one is a big problem! It jmakes it almost unusable to have to get up and reboot it all the time.
Also several very important features are missing from this device:
Alexa Communication features dont work.
It wont work as a multi room spekaer
There is no way to output sound to another device or input sound from another device.
You are better off just buying a 30$ echo dot and hooking a speaker up to it. Then you will have these features.
No RepliesBe the first to reply
