inteller
Jul 06, 2019Apprentice
DO NOT UPGRADE RBR/RBS40 to 2.3.5.30 YOU HAVE BEEN WARNED!
As usual if you are a NETGEAR Customer YOU ARE THE BETA TESTER!!!!!! This firmware is ABSOLUTE and COMPLETE GARBAGE! iOS devices WILL NOT STAY CONNECTED with this update. Samsung mobile devices al...
komrade
Jul 08, 2019Guide
Seeing the same issue on RBR20. Can't even connect to the router because it won't assign an IP address. Something to do with the DHCP maybe?
- intellerJul 08, 2019ApprenticeNetgear should be ashamed for pushing out this garbage.
- komradeJul 08, 2019GuideI previously had my Guest network turned off. Connected a laptop via Ethernet to the main Router, enabled the Guest network and can connect to the internet through the Guest. Still can't get my regular network to give a device an IP though. Not confident it will last though...
- intellerJul 08, 2019ApprenticeYou should not be forced to use the guest network just to get your router to work. I experienced just the opposite, guest network made things worse.
UTTER GARBAGE NETGEAR!!!!
