inteller
Jul 06, 2019Apprentice
DO NOT UPGRADE RBR/RBS40 to 2.3.5.30 YOU HAVE BEEN WARNED!
As usual if you are a NETGEAR Customer YOU ARE THE BETA TESTER!!!!!! This firmware is ABSOLUTE and COMPLETE GARBAGE! iOS devices WILL NOT STAY CONNECTED with this update. Samsung mobile devices al...
inteller
Jul 08, 2019Apprentice
Netgear should be ashamed for pushing out this garbage.
komrade
Jul 08, 2019Guide
I previously had my Guest network turned off. Connected a laptop via Ethernet to the main Router, enabled the Guest network and can connect to the internet through the Guest. Still can't get my regular network to give a device an IP though. Not confident it will last though...
- intellerJul 08, 2019ApprenticeYou should not be forced to use the guest network just to get your router to work. I experienced just the opposite, guest network made things worse.
UTTER GARBAGE NETGEAR!!!!- komradeJul 08, 2019Guide
got mine working for now:
- Connected laptop to main Router via Ethernet
- Set a Static IP (Advanced -> Setup -> LAN Setup) and Add an Address Reservation for the laptop
- Turn off DHCP on Router
- Reboot Router
- Wait a few minutes for it to come fully back online
- Test connection with just Ethernet (mine worked fine)
- Re-enable DHCP
- Wait 5 minutes for it to fully load and devices should start to reconnect
Does that work for you?
- intellerJul 08, 2019ApprenticeThat is a complete garbage solution and you need to realize there are households with no ethernet ports on their devices.
