inteller
Jul 06, 2019Apprentice
DO NOT UPGRADE RBR/RBS40 to 2.3.5.30 YOU HAVE BEEN WARNED!
As usual if you are a NETGEAR Customer YOU ARE THE BETA TESTER!!!!!! This firmware is ABSOLUTE and COMPLETE GARBAGE! iOS devices WILL NOT STAY CONNECTED with this update. Samsung mobile devices al...
Kmaniei
Jul 08, 2019Aspirant
The new firmware changed all the static ip addresses in my network. I had to login from my computer and reassign them. Total garbage. All because wants to force a trial version of anti virus. But the main issues is lowering the wifi connection from 280mb to 20-30mb for no reason. Netgear., Please provide downgrade option. My 8 years old wireless router works better than 3 netgear orbi now. This is absolutely unacceptable.
inteller
Jul 08, 2019Apprentice
You can manually downgrade, that's what I did. Had to log into the sat and downgrade it manually first, then the router.
