CHRSBNHM
Jul 17, 2019Aspirant
Do Orbi satellites act as unmanaged switches? (e.g. RBS50)
Hi, This might seem like an obvious question but I haven't been able to confirm one way or the other through documentation. I've recently bought the RBK53 for my household and planning to have one o...
- Jul 17, 2019
Most networking devices and the switches on Orbi work as a switch. The switch depending upon configuration and destination will directly traffic to the destination device. If the two devices are on the same RBS, then the traffic should go directly to the connected device, not the the RBR then back to the RBS.
CHRSBNHM
Thanks for the quick response! What you're saying makes sense - so if two devices were plugged into the same satellite via RJ45 (both devices capable of gigabit ethernet) and say you wanted to copy a file from one to the other. Would that data go from the device to the satellite at 1000Mbps (or whatever the real world speed is), from the satellite to the main router over WiFi (or ethernet backhaul if configured), then back again to the satellite before going to the other device (that final leg being 1000Mbps)?
Or does the satellite act a bit like a switch, allowing the two devices to communicate "directly" without the need for all the data to flow via the router?
Jul 17, 2019Guru - Experienced User
