mgreene007
Jun 10, 2019Follower
docsis3.1 cable modem router
Does Orbi come in a docsis 3.1 cablemodem router configuration. I have a 2000 sq ft. condo and Cox is requireing one! I use Orbi router with 2 sattilites at home and LOVE it!
Jun 10, 2019Guru - Experienced User
If you already have an orbi setup, I'd just buy a docsis 3.1 modem and keep using your current setup. My own opinion is seperation of modem and router are the best because if a combo device fails, you've lost router and modem. cheaper to replace, plus you're in control of your own firmare updates versus the isp controlling firmware.
- michaelkenwardJun 11, 2019Guru - Experienced User
I'm with plemans but with the added advice that you check that you can a modem only version. Many docsis devices are modem/routers. In Netgear's range look for the CMXXX model numbers rather than anything CXXXX.
Another advantage of having a separate router is that cable modems are locked down by the Internet service providers, which do not allow anyone to update firmware on modems. So you can end up with a modem/router where the router bit is not as up to date as it can be with a separate router.
