rcudd
Oct 28, 2021Follower
Does a Netgear Mesh RBS50 satelite work with and Netgear Mesh Orbi RBK40 router?
Does a RBS50 satelite work with and RBK40 router? I've had a RBK40 system in place for a while with 3 satelites and I wanted to order a 4th. I wasn't able to source an RBS40 satelite so ended up bu...
Oct 28, 2021Guru - Experienced User
Yes it does.
the only ones not compatible with the RBR40 are the 10 series and the newer AX verisons.
so you can use:
RBS20
RBW30
RBS40
RBS40V (used to go on sale a lot)
RBS50
RBS50Y
