boxersoft
Dec 13, 2019Aspirant
Does an ethernet connection prevent daisychaining?
I have an Orbi RBR50 router and two RBS50 satellites, all with firmware V2.3.5.30. The Router is at one end of the house, satellite S1 at the other and S2 in an outbuilding, forming an L-shaped arran...
- Dec 13, 2019
> there is no dollar cost to experiment. Only time.
And wear & tear on my knees, as I have to crawl through loft spaces to reach them :smileyhappy: I'll give it a try over the weekend though and report back - thanks again for the suggestions.
CrimpOn
Dec 13, 2019Guru - Experienced User
I honestly have no idea WHY these Orbi units are behaving the way they are. One thought is that they have "learned" that the backhaul path is S2 to S1 to the router. When S1 no longer needs to go through S2 (ethernet), S2 is not smart enough to say, "Wow. Look. It's better to go through S1 than directly to the router!"
That's why I would consider having the router "forget" both satellites. "Add" S1 on ethernet backhaul. Then "Add" S2, and it should pick the good connection through S1 over the weak connection direct to the router.
Anyway, there is no dollar cost to experiment. Only time.
boxersoft
- boxersoftDec 14, 2019Aspirant
Yep, that seems to have worked - thanks. When S2 first connected after moving back to its proper location it briefly claimed a connection to the Router, but after a couple of status "blinks" it changed to S1 and appears to have settled on that. I'm not entirely convinced the initial display was correct anyway, as it claimed it was a "5G, Good" connection to the Router, and I don't think that's credible. The current "5G, Good" connection to S1 is credible though, and it seems stable. Happy with that.
PS: Is there any way to include inline images in posts on this forum? I tried to do that with my little diagram of the locations but I could only find the option of attaching, which isn't very convenient for readers.
- CrimpOnDec 14, 2019Guru - Experienced User
boxersoft wrote:PS: Is there any way to include inline images in posts on this forum? I tried to do that with my little diagram of the locations but I could only find the option of attaching, which isn't very convenient for readers.
When I click on the "Photos" icon, I can inset certain file types. Here's a screen shot of my DHCP lease
That's what I expected to be able to do, but I don't see a Photos button or anything similar on the message editor toolbar. I see buttons to insert a "spoiler", code, emoticon, link, video, numbered and bulleted lists amongst formatting options, but nothing for images.
