Beeldbuisje
Feb 28, 2021Guide
Does an RBR50 has known problems with Apple HomeKit devices?
I own this Router for 2 years now, fully satisfied. It's set as an accesspoint. Last year I bought a Netatmo doorbell. Should work with HomeKit, but his Security app gives the message: not connected...
Feb 28, 2021Guru - Experienced User
What actual router are you using as primary?
If the RBR50 is setup in access point mode, its routing features are going to be disabled so its more going to be whatever router the rbr is connected to.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Beeldbuisje
Mar 01, 2021Guide
It's connected directly to my Telenet (Belgium) ISP router/modem.
I already asked the same question to them, normally HomeKit features are 100% compatible with their routers.
Thanks for this info, I already hesitated for a problem around the doorbell itself...
- plemansMar 01, 2021Guru - Experienced User
what actual modem is it?
Can you put it in passthrough/modem only mode? And then the orbi back in router mode?
- BeeldbuisjeMar 04, 2021Guide
On that Telenet modem is almost nothing to adapt. You can change wifi network, password, wireless on/off, that's it.
- BeeldbuisjeMar 07, 2021Guide
I also found the possibilities of port-forwarding in this Telenet modem. But this doesn't give a solution here I guess...
