Beeldbuisje
Feb 28, 2021Guide
Does an RBR50 has known problems with Apple HomeKit devices?
I own this Router for 2 years now, fully satisfied. It's set as an accesspoint. Last year I bought a Netatmo doorbell. Should work with HomeKit, but his Security app gives the message: not connected...
Beeldbuisje
Mar 01, 2021Guide
It's connected directly to my Telenet (Belgium) ISP router/modem.
I already asked the same question to them, normally HomeKit features are 100% compatible with their routers.
Thanks for this info, I already hesitated for a problem around the doorbell itself...
Mar 01, 2021Guru - Experienced User
what actual modem is it?
Can you put it in passthrough/modem only mode? And then the orbi back in router mode?
- BeeldbuisjeMar 04, 2021Guide
On that Telenet modem is almost nothing to adapt. You can change wifi network, password, wireless on/off, that's it.
- BeeldbuisjeMar 07, 2021Guide
I also found the possibilities of port-forwarding in this Telenet modem. But this doesn't give a solution here I guess...
