fgard
Nov 01, 2020Aspirant
Does anyone know if the Orbi RBR40 will work with the BT Smarthub 2?
BT want us to upgrade from the homehub 3.0 to the Smarthub2. We currently have a separate modem with the homehub. Looking at the connectors on the Smarthub2 this seems to replace the modem as wel...
Nov 01, 2020Guru - Experienced User
If the modem or ONT have a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options with Orbi systems,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
