May 09, 2018Guide
Does Daisy Chaining work? RBK50
Hi Everyone,
I have the RBK50 package with the RBR50 + 1 x RBS50.
I'd like to add an additional RBS50 but it would only work if daisy chaining works, as the 2nd RBS50 would be too far from the RBR50.
I've seen a LOT of forum posts about problems with daisy chaining and the general recommendation seems to be to disable it.
Am I asking for trouble?
Thanks everyone!
1 Reply
- JeremyinsfApprentice
You might want to wait until the firmware stabilizes a bit. Or buy it and try it - as long as you can return it.
My take is that people are having different experiences based on their own devices and topology. Some may be having problems and not even realize it, and others are running just fine.
