oiyq2
Apr 03, 2020Follower
Does doing a hard reset on the router wipe the firmware upgrades I have already done?
So I have forgotten my admin password to my RBR50, and my answers to the security questions aren't working. I have it written down, but is far away in another country. What I'm left with is doing a...
michaelkenward
Apr 04, 2020Guru - Experienced User
Retired_Member wrote:
oiyq2 wrote:
My question is, if I do a hard reset/factory reset, do I lose all the firmware updates I have already done? If so, I would likely just keep it as is for now.
Thank you in advance!
My guess...(ouch)...is that IF you do a factory reset, as the name implies, your Orbi will be set back to the way it was coming out of the box.
No. Big time.
Read the manuals and you will see that it means that all of the default settings go back to their Factory default settings or factory configuration.
There really isn't any such thing as "factory settings" when it comes to the firmware version. As boxes come off the production line they emerge with the current firmware. By the time the thing reaches the customer there may have been several new versions.
Stuff like the RBR50 has been around for some time. It will have left the factory with various versions of the firmware.
Retired_Member
Apr 04, 2020
No. Big time.
OK...big time....I believe ya.
for what its worth....i try and stay away from so-called factory resets.
